[GiDlist] Field name in a .BAS file.
I am writing a .bas file and I would like to ask you whether it is possible to get the name of a field inside a loop over materials. I have written in the .mat file something like :
QUESTION : ELASTIC_MODULUS
VALUE : 205000
and I would like to write in the .dat file :
Material.put(ELASTIC_MODULUS, 205000)
can I get the name of the filed (“ELASTIC_MODULUS”) by a command like *MatProp(0) for the material’s name, or sould I write for each field :
*loop materials
*MatProp(0).put(ELASTIC_MODULUS, *MatProp(1))
*MatProp(0).put(POISSON_RATIO,*MatProp(2))
*end
Christophe Louis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020925/9eb10413/attachment.htm
It is not available directly in the bas file to recover the name of a field,
and it is recommended to use *Matprod(ELASTIC_MODULUS) instead *MatProp(1) ,
is more human readable, and easy to mantain (if you add or remove fields is not necessary to renumber)
For advanced users, it is possible to obtain the fields and values of a material from tcl, with a info command
.central.s info materials
return a list with all the material names
.central.s info material “material_name”
return a list with the fields and values of this material
It is possible to create a procedure inside the file “problemtypename”.tcl, and call this procedure from the bas file
with the order *tcl(tclcommand)
The returned string is printed directly to the output file.
For more info, download the “advanced course documentation” at
http://gid.cimne.com/2002/material_courses.subst
To: Gid
Sent: Wednesday, September 25, 2002 4:31 PM
Subject: [GiDlist] Field name in a .BAS file.
VALUE : 205000
*loop materials
*end
Christophe Louis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020925/8bfa4c4a/attachment.htm
