[GiDlist] Extruding by batch file command
i am trying do automatically generate a volume via batch file. This is
intended to be created by defining a cross-section (as set of surfaces),
that shall be extruded along a nurbs line into a volume.
Unfortunately, neither the Sweep nor the Extrude option works from the
GiD command line or batch file.
Do you have any suggestions?
Kind regards
Janosch
