One of the possibilities to do it is with the “Mesh Read” command:
“With this option it is possible to read a mesh in order to visualize it
within GiD.
It is also possible to read a new mesh and add it to the existent one. In
this case,
the user is prompted to keep the former one or join it to the new mesh.”
So, you can create a mesh, save it and start a new project where you can
generate the other elements and add the old mesh.
J.
[mailto:owner-gid at gatxan.cimne.upc.es]En nombre de Gunaratnam
Gnanaranjan
Enviado el: miercoles, 06 de junio de 2001 20:40
Asunto: [ GiDlist ] elements
Hi All
I wonder if it is possible to generate two type of
elements in the same model using GID.
ie: For example a quadratic brick element and a linear
line element.
I know we can generate different elements of the same
order(say only linear or only quadratic).Is it
possible to have both types together.Just curious to
know this.
gnana
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
Name: Imagen (Mapa de bits independiente del dispositivo )
Type: application/x-microsoft-ole-object
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010606/dae66d0c/attachment.bin
Thanks.
One more question.Is there any comprehensive tutorial
available on creating contacts.
I am trying to do a soil pile analysis.I represent the
pile with a linear element in a 3D soil mass.ie: a
line element within a cylindrical hole of the same
diameter as the actual pile in the soil mass.I couple
the displacements of pile nodes and soil nodes at the
same level.I attach a view of the model.Can I use
‘contact’ to couple pile node and the sorrounding soil
nodes.
gnana
— Javier Mora mora at cimne.upc.es wrote:
One of the possibilities to do it is with the "Mesh
Read" command:
"With this option it is possible to read a mesh in
within GiD.
this case,
it to the new mesh."
J.
Gunaratnam
Gnanaranjan
Hi All
linear
line element.
same
know this.
gnana
Do You Yahoo!?
only $35
_a year! http://personal.mail.yahoo.com/_
ATTACHMENT part 2 application/x-microsoft-ole-object
name=Imagen (Mapa de bits independiente del
dispositivo )
Do You Yahoo!?
Type: image/gif
Desc: pile-01.gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010606/78695146/attachment.gif
