i generated 3d structured grids and tried to export them to autocad200 with writedxf. it failed. does anyone know how to export 3d grids to Autocad?
it works with 2d-elements but with 3d the problemtype calculator writes the dxf-file but the system tells me that there is an error and the dxf is empty.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011023/a73a865b/attachment.htm
The dxf is written with Files-Import/Export-Dxf Write (useful to export points an curves)
or with a problem type writting directly the mesh (nodes and elements) ??
Please, send us the GiD sample, and the problemtype used.
Note: you cand send confidencially to: escolano at cimne.upc.es
To: Gidlist
Sent: Tuesday, October 23, 2001 10:43 AM
Subject: [ GiDlist ] DXF-Writing
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011023/f222d16d/attachment.htm
