I think you’ll find it does in 7.7.7b , if you don’t erase the point id number but just change the coordinates nothing seems to happen and the coordinates revert to the point with that id.
I’d like to see improvements to
- copy & move rotate where instead of defining the angle you define the rotation axis and a start & end position for one point.
- When generating a circle you have to specify a radius & cannot just select an existing point for the circle to go throuh,
- generating an arc by selecting 2 end points and a radius.
- generate a line at a tangent to a curve at a point of a given length.
You can do all these thing in a round about manner but it would be nice to do it easily
I’ve also noticed that sometimes when I select to view the right button tool bars the working space grays out & noting I do can bring it back so I have to shut down & start again?
mark
-----Original Message-----
From: gidlist-admin at gatxan.cimne.upc.edu [mailto:gidlist-admin at gatxan.cimne.upc.edu] On Behalf Of Franco Giuggioloni
Sent: 29 November 2006 22:15
Subject: [GiDlist] does anyone has this problem in Gid 8?
Hello , I have this question since you are taking about Copy and Paste
Im using Gid 8 for Linux and when I use Copy or Move command I have this problem; Suppose I want to move (or copy) a surface in only one direction, If I select the same point for the first and second in the Move/Copy window and I change only one coordinate for the second point , I must erase the point designation (number). If I dont erase it, the surface (or line,point) wont move. Is this the correct procedure? Its not a very important problem but it doesn`t exist in Gid 7, for example
best regards
Franco Giuggioloni
fgiuggioloni at iua.edu.ar
Aula Cimne Cordoba
Instituto Universitario Aeronàutico
Cordoba,Argentina
This message (including any attachments) contains confidential
and/or proprietary information intended only for the addressee.
Any unauthorized disclosure, copying, distribution or reliance on
the contents of this information is strictly prohibited and may
constitute a violation of law. If you are not the intended
recipient, please notify the sender immediately by responding to
this e-mail, and delete the message from your system. If you
have any questions about this e-mail please notify the sender
immediately.
