[GiDlist] displaying quadratic elements
Miguel
I can convert a mesh into a wireframe mesh of lines which I can then import
into GiD to see all the mid-side nodes (via a .bas file and a little mesh
cleanup routine) but it occurred to me that I could convert it into surface
geometry file (and then able to see a non faceted mesh) if only I knew what
GiD’s .geo file format was, would you be prepared to put this information
into the public domain?
Or is there an alternative method of saving a mesh as geometry?
Mark
-----Original Message-----
From: Miguel A. de Riera Pasenau [mailto:miguel at cimne.upc.es]
Sent: 01 August 2002 13:22
Subject: Re: [GiDlist] displaying quadratic elements
now th only way to show the position of the middle nodes is
to draw the labels of these nodes. the middle nodes are not
drawn due to performance questions. we are planning to add
an option to drawn those middle nodes just with interconected lines
( not curves).
Mark Smith wrote:
Win98 GiD 6.3.0b
Dear GiD team
When I label the nodes of a quadratic element mesh I can see the mid-side
node numbers but the mesh shown is the simple linear one. Is there any way
of showing the quadratic mesh or are there any plans to do so?
Like wise, the rendered surface of a quadratic mesh appears far more
faceted
than is the case, which make it difficult to judge how well the surface
mesh
approximates the geometry.
Can we have an option in preferences to show quadratic curved elements,
both
normal and rendered.
Can you clarify what the meaning of the mesh quality window is for
quadratic
elements? since it reports the same information irrespective of the
element
order (linear or quadratic).
Mark
+44 (0)1480302100
_http://www.linx.co.uk/_
person.
business of Linx shall be understood as neither given nor endorsed by
Linx.
Miguel A. de Riera Pasenau miguel at cimne.upc.es
+44 (0)1480302100
person.
1- It is easy create a small template .bas to convert the surface mesh to wireframe mesh.:
Example (for quatratic triangles and repeating shared edges)
Wireframe.bas
MESH dimension 3 ElemType Linear Nnode 2
Coordinates
*loop nodes
*nodesnum *nodescoord
*end nodes
end coordinates
Elements
*set var cont=0
*loop elems
*set var cont=operation(cont+1)
*cont *elemsconec(1) *elemsconec(4)
*cont *elemsconec(4) *elemsconec(2)
*cont *elemsconec(2) *elemsconec(5)
*cont *elemsconec(5) *elemsconec(3)
*cont *elemsconec(3) *elemsconec(6)
*cont *elemsconec(6) *elemsconec(1)
*end elems
end elements
A quadratic triangle can be written also as four linear triangles.
Copy this file Wireframe.bas inside the directory /templates, and use it with
Files-Export-Using Template bas (only mesh)-Wireframe
After , read the ouput file with Files-Import-GiD mesh
2- You can convert the surface mesh to geometry (DXF format) using the template DXF.bas
Files-Export-Using Template bas (only mesh)-DXF
Note: this template write quadratic elements as linear, but it can be modified.
3- If you have interest to read/write directly the GiD .geo format, I’ attach a beta documentation of this format
(this document is spanish language and word format)
Sent: Thursday, August 01, 2002 4:33 PM
Subject: RE: [GiDlist] displaying quadratic elements
Miguel
Mark
( not curves).
Mark Smith wrote:
Win98 GiD 6.3.0b
Dear GiD team
faceted
mesh
both
quadratic
element
Mark
+44 (0)1480302100
person.
Linx.
+44 (0)1480302100
person.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020809/054f5e76/attachment.htm
Name: Formato gid 6.2b.doc
Type: application/msword
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020809/054f5e76/attachment.doc
