Is it possible to customise the automatic comments which are displayed in
postprocessing?
if I have in my .res file sets of results like:
Result “Drop position” “at time” 5.7000e-005 Vector OnNodes
Values
666 5.4928e-004 -1.3700e-004 1.2295e+000
end values
in the postprocessing comment I get :
Deformation ( x1): Drop position of at_time, step 5.7e-005.
Q1) is there any way of suppressing or changing: Deformation
( x1):
( The factor (x1) is what I set in : window:deform mesh:mesh deformation etc
Q2) is there any way of suppressing or changing the text : of
Q3) is there a way of suppressing the underscore _ in at_time
Which if any of the script files might I need to change?
Mark
+44 (0)1480302100
http://www.linx.co.uk/
person.
it is only possible to switch on or of (utilities-Graphical-coments)
the complete automatic comments, not just one part.
i’ll remove the ‘_’ which, in fact, should not be present.
these automatic comments are generated inside GiD, not in tcltk scripts.
a good idea will be to let the user create its own comments, a la ‘word’,
i.e. for instace: ‘showing %r at step %s’, being ‘%r’ the name of the
displayed result and ‘%s’ the current step. - next version of GiD.
postprocessing?
Values
end values
( x1):
Mark
+44 (0)1480302100
_http://www.linx.co.uk/_
person.
