[GiDlist] Custom HTML
OS win98 GiD 6.3.0
Hi Gidteam,
  1. Do you have any plans for the html browser plugin to support animated
    gifs ? It doesn’t show them at this moment.
  2. I produce a results file with a sequence of displacements of a point at
    known time intervals i.e.
    Result “Displacements” “movement” 1 Vector OnNodes
    Values
    224 2.2830e-004 8.7118e-007 1.2855e+000
    end values
    Result “Displacements” “movement” 2 Vector OnNodes
    Values
    224 1.1230e-003 3.9503e-006 2.6389e+000
    end values
etc…
Is there a method of associating a time value at each step so that
Utilities:graphics:comments displays the time rather than just the step
number during an animation?
Thanks in advance
Mark
+44 (0)1480302100
http://www.linx.co.uk/
person.
  1. the html browser uses Tk’s gif image widget, and
    until now we didn’t thought showing animated gifs in gid’s html help.
    It is an interesting option, we can include it in the plan
    for the next version of gid.
To show the time value, just write it on the results header,
instead of the step number, in your case:
Result “Displacements” “movement” 0.5 Vector OnNodes
note the time step value -------^^^
Values
end values
Result “Displacements” “movement” 1.0 Vector OnNodes
Values
end values
Result “Displacements” “movement” 1.5 Vector OnNodes
Values
end values
Result “Displacements” “movement” 2.0 Vector OnNodes
Values
end values
for time steps 0.5, 1.0, 1.5 and 2.0.
Mark Smith wrote:
OS win98 GiD 6.3.0
Hi Gidteam,
1) Do you have any plans for the html browser plugin to support animated
2) I produce a results file with a sequence of displacements of a point at
Values
end values
Values
end values
etc…
Thanks in advance
Mark
+44 (0)1480302100
_http://www.linx.co.uk/_
person.
