I’ m working with BEM in a pipelike geometry, and i need that the order of
the nodes of and element generate a normal vector pointing outside the
surface, the numeration of the nodes must be counterclockwise. Reading the
mesh in a GID format (.msh) i realice that this statement it`s right for the
“outer” surface of the mesh but in the “inner” surface of the pipe the
normal vector points inside the body. This can be avoided?, i’ m making some
mistake?
Thanks in advance.
Johane Bracamonte
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060804/a82eca33/attachment.htm
Usually, when you create a volume in GiD, the boundary surfaces are oriented with normal pointing inside the volume.
In any case, you can change this orientation: menu Utilities-Swap normals-Surfaces
When you generate a mesh, the element’s normals are the same as the source surface normals.
Sent: Friday, August 04, 2006 11:26 PM
Subject: [GiDlist] counterclockwise order of the nodes
I’ m working with BEM in a pipelike geometry, and i need that the order of the nodes of and element generate a normal vector pointing outside the surface, the numeration of the nodes must be counterclockwise. Reading the mesh in a GID format (.msh) i realice that this statement it`s right for the “outer” surface of the mesh but in the “inner” surface of the pipe the normal vector points inside the body. This can be avoided?, i’ m making some mistake?
Thanks in advance.
Johane Bracamonte
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060807/0c44f836/attachment.htm
Check menus:
View-Normals
En Fri, 04 Aug 2006 23:26:06 +0200, Johane Bracamonte johanehb at gmail.com
of
the
the
some
mistake?
Thanks in advance.
Johane Bracamonte
