¿ have you tried going to Preferences – Graphical and in the Drawing method block selecting Display Lists instead of Vertex Buffer Objects ?
I tried with a simple quad8 example on gid 11.0.6 and it worked for me:
Miguel Pasenau
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de HEMMI, Shigeru
Enviado el: jueves, 18 de septiembre de 2014 23:33
Asunto: Re: [GiDlist] Contour fill problem of QUAD4
Dear Dr. Enrique Escolano,
Thanks for the reply.
You wrote:
We will not pack any version 11.x more, we will release only new versions 12.x
In Japan, as a buisiness custom, one year guarantee is often provided for commercial products.
It is some 10 months before since I paid GiD 11 license.
Since 10 monthes is less than 1 year, it is my hope you pack and provide fixed GiD 11 version for me.
For another well known sample as a commercial custom, Microsoft provides security fixes
and some bug fixes for their Windows OS or other products for certain periods.
Thus I believe it is not a miracle if you provide fixed version of the GiD 11.
Hope this changes your mind.
Best regads,
HEMMI, Shigeru
2014-09-15 22:09 GMT+09:00 Enrique Escolano escolano at cimne.upc.edu:
Any version will be never completely free of some bug, version 11.1.9d is good enough !!
About its known bugs, you can avoid them, e.g. to insert a model over another you must first generate a mesh in the current model to avoid the crash.
I remember that you can have installed more than one GiD version, each one is located in a different folder, then decide yourself which is better for your use (in my opinion 11.1.9d is the best 11.x version)
And you can use the win x32 version also in an x64 operating system
Enviado el: sábado, 13 de septiembre de 2014 2:37
Para: Enrique Escolano; gidlist at listas.cimne.upc.edu
Thanks for the support but Im still annoying.
First I do not have the license of GiD 12.
I would like to solve problemes within GiD 11.
Please remember that GiD 11.1.9d is not free from crashing; See
http://listas.cimne.upc.edu/pipermail/gidlist/2014/005063.html
http://listas.cimne.upc.edu/pipermail/gidlist/2014/005066.html
and your recommendation was to use GiD 11.0.8 Windows x32,
http://listas.cimne.upc.edu/pipermail/gidlist/2014/005076.html
Which version should I use?
Best regads,
HEMMI, Shigeru
2014-09-13 0:27 GMT+09:00 Enrique Escolano escolano at cimne.upc.edu:
The square was drawn for the contour fill as two triangles, and for a coarse mesh the underlying unsymmetric mesh is visible in the image.
Latest GiD versions use four triangles (with an inner extra node) that provide a more symmetric interpolation.
You can use the current GiD 12 version or also the last GiD 11.1.9d version (with your current 11.x password),
This is the image obtained with these versions:
Enviado el: jueves, 11 de septiembre de 2014 6:23
Asunto: [GiDlist] Contour fill problem of QUAD4
Dear GiD team,
I encountered a GiD problem in 2D post processing.
For a calculated result given in the post.msh,
MESH dimension 2 ElemType Quadrilateral Nnode 4 Coordinates
3358 1.54340557 0.025 0
3368 1.54340557 0.0125 0
3378 1.54340557 0 0
3400 1.56294235 0.025 0
3405 1.56294235 0.0125 0
3419 1.56294235 0 0
3435 1.57865031 0.025 0
3440 1.57865031 0.0125 0
3446 1.57865031 0 0
3475 1.59818709 0.025 0
3481 1.59818709 0.0125 0
3487 1.59818709 0 0
End Coordinates
Elements
80 3419 3405 3368 3378 8
160 3405 3400 3358 3368 8
3201 3446 3440 3405 3419 8
3202 3440 3435 3400 3405 8
3241 3487 3481 3440 3446 8
3321 3481 3475 3435 3440 8
End Elements
and post.res files,
GiD Post Results File 1.0
Result “nodalOutput” “iStep” 0 Scalar OnNodes ComponentNames “Something”
Values
3358 0.763791
3368 0.876752
3378 1
3400 0.589664
3405 0.65474
3419 1
3435 0.410336
3440 0.34526
3446 0
3475 0.236209
3481 0.123248
3487 0
End Values
The GiD output of contour lines is valid but the contour fill is invalid, the latter is not symmetric with respect to the vertical center line.
Please take a look at the attachment figure.
GiD seems doing incorrect interpolation for contour fill of QUAD4 element.
I’m using GiD 11.0.8 and my PC is Windows 8.1 pro 64bit.
HEMMI, Shigeru
Este mensaje no contiene virus ni malware porque la protección de avast! Antivirus está activa.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140919/32b6e8bc/attachment-0001.htm
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140919/32b6e8bc/attachment-0001.png
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140919/32b6e8bc/attachment-0003.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140919/32b6e8bc/attachment-0004.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140919/32b6e8bc/attachment-0005.jpeg
