[GiDlist] combination of quadratic elements and normal eleme
Hi all,
I have a question concerning the mesh process. In my geometry I’ve got volumes and lines. I want to mesh the volumes with quadratic elements and the line elements with normal (linear elements) because the line elements should represent spring elements. In my mesh now all the elements are meshed with quadratic elements. Is it possible to mesh only the volumes with quadratic elements and the lines with linear elements?
Jeff
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140212/8658dbad/attachment.htm
Dear Jeff,
It is not possible to do so with GiD: the quadratic property is applied to
the whole mesh (with all the kinds of elements generated.
Kind regards,
ABEL
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Bronsert, Jeffrey
Enviado el: miércoles, 12 de febrero de 2014 15:42
Asunto: [GiDlist] combination of quadratic elements and normal elements
Hi all,
Jeff
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140212/92fe2e1c/attachment.htm
Hi Jeff,
Now is not possible to generate part of a mesh quadratic and part linear,
because Quadratic is a global variable (not a local setting attached to each
entity)
You can do some other tricks, like write for your solver the quadratic line
elements like linear, ignoring the third node, or write it but ignore its
quadratic node for the calculation, etc.
Hi all,
Jeff
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140212/db0e1009/attachment.htm
Hi Enrique and Abel,
thanks for your quick reply
Kind regards
Jeff
Von: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] Im Auftrag von Enrique Escolano
Gesendet: Mittwoch, 12. Februar 2014 16:36
An: gidlist at listas.cimne.upc.edu
Betreff: Re: [GiDlist] combination of quadratic elements and normal elements
Hi Jeff,
Now is not possible to generate part of a mesh quadratic and part linear, because Quadratic is a global variable (not a local setting attached to each entity)
You can do some other tricks, like write for your solver the quadratic line elements like linear, ignoring the third node, or write it but ignore its quadratic node for the calculation, etc.
De: gidlist-bounces at listas.cimne.upc.edumailto:gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Bronsert, Jeffrey
Para: gidlist at listas.cimne.upc.edumailto:gidlist at listas.cimne.upc.edu
Hi all,
Jeff
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140213/fabbdbdf/attachment-0001.htm
Hello.Is there a way to deal with vectors and matrices to store and print data when dealing with the .bas file?
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140303/15818bde/attachment.htm
No, the .bas language doesn’t support any kind of array.
To do complicated thinks you can invoke from the .bas file a Tcl command
*tcl(procedure_name). The value returned by the procedure is directly
printed to the output file.
Tcl/Tk is a full and powerful scripting language with all you can need (also
arrays off course). You can find information about it in the GiD help, and
in Internet.
You can see the Tcl documentation for example from the RamDebugger Help
(Data-Problemtype-Debugger, or press F11 to open it)
This documentation (Html format) is locally stored at C:\Program
Files\GiD\GiD 11.1.8d\scripts\ramdebugger\help
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de David R. José
Enviado el: lunes, 3 de marzo de 2014 23:18
Asunto: [GiDlist] Vectors and matrices
Hello.
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140304/e2989d61/attachment.htm
Dear Mr. Escolano, thanks for your reply.I’ll look into tcl/tk programming.
In an unrelated issue: can an “if” statement be triggered by the existence of a condition?Say, for example, I loop around the nodes and if a node has a condition, then the “if” is triggered.Something like:loop nodesif ( “condition of node constraint exists on that node” )…*end nodes
Thanks in advance.
Subject: GiDlist Digest, Vol 44, Issue 1
Date: Tue, 4 Mar 2014 12:00:01 +0100
gidlist-request at listas.cimne.upc.edu
Today’s Topics:
1. Vectors and matrices (David R. Jos?)
2. Re: Vectors and matrices (Enrique Escolano)
Message: 1
Date: Mon, 3 Mar 2014 19:17:56 -0300
Subject: [GiDlist] Vectors and matrices
To: “gidlist at listas.cimne.upc.edu” gidlist at listas.cimne.upc.edu
Message-ID: BAY169-W1072C4D572370CBB27AE242C48F0 at phx.gbl
Content-Type: text/plain; charset=“iso-8859-1”
Thanks!
_URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140303/15818bde/attachment.html_
Message: 2
Date: Tue, 4 Mar 2014 11:40:04 +0100
Subject: Re: [GiDlist] Vectors and matrices
Message-ID: 00c001cf3796$1a69ff10$4f3dfd30$@cimne.upc.edu
No, the .bas language doesn?t support any kind of array.
in Internet.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de David R. Jos?
Hello.
Thanks!
_URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140304/e2989d61/attachment-0001.htm_
End of GiDlist Digest, Vol 44, Issue 1
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140304/af82a84e/attachment.htm
Yes, you can use if statements of some condition field, but to use some
*cond(your_field) command you must before use *set cond xxx and do the loop
*onlyincond (that will loop only in the nodes with this condition applied)
e.g.
*set cond your_condition
*loop nodes *onlyincond
*if(cond(your_field,int)==1)
THE NODE *nodesnum HAS APPLIED A CONDITION your_condition with value
equal to 1
*endif
*end nodes
Note that inside the *if is not necessary the asterisk for *cond(), and in
this case I also specificied the ,int parameter to say that this field must
be considered as an integer
Enviado el: martes, 4 de marzo de 2014 15:34
of a condition?
Something like:
*loop nodes
*if ( “condition of node constraint exists on that node” )
*end nodes
Thanks in advance.
Today’s Topics:
Message: 1
Thanks!
URL:
attachment.html
Message: 2
(also
in Internet.
Hello.
Thanks!
URL:
attachment-0001.htm
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140304/d19ad4bd/attachment-0001.htm
