[GiDlist] Cast3M
Hola!!
¿Es posible realizar un postproceso con Gid de un problema dinámico resuelto con Cast3M? ¿Cómo puedo hacerlo ? Gracias.
Ignacio
ETSECCPB
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040714/57488fe7/attachment.htm
GiD cannot directly read Cast3M results.
You must transform this results in a GiD postprocess file.
This format is documented in the GiD help: see “Postprocess data files”
GiD can also read FEMAP neutral results files, and Tecplot results files. I unknow if Cast3M can export this kind on files.
Sent: Wednesday, July 14, 2004 7:12 PM
Subject: [GiDlist] Cast3M
Hola!!
Ignacio
ETSECCPB
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040716/d155168d/attachment.htm
