[GiDlist] CAN'T generate volume mesh
Hi, everyone
I am a new user of GiD. I got a question about how to
generate volume mesh from surface geometry or surface
mesh.
My problem is in twofold. First, I have a surface
geometry (see attachment volume_bad.geo – an example
in advanced tutorial, I did not find the respective
solution there) but I can’t generate volume entity (by
creating a volume in GiD), thus I can’t generate
volume mesh. Second, I have a surface mesh and I can
generate volume entity (by creating volume with search
option in GiD). When I am trying to generate volume
mesh, it gave me wrong message like (problematic
surfaces: 14) and so on.
Could anyone tell wether this is due to wrong surface
geometry or surface mesh, or is there any way out to
fix it manually on problematic surfaces?
thanks
Henry Liu
Henry Liu
Post your free ad now! http://personals.yahoo.ca
Desc: volume_bad.geo
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041012/5bceb714/attachment.obj
Hi Henry,
I use to generate a volume mesh (hexahedras) from a surface like
following:
  1. Once you finish the geometry (surface), just mesh it. I.e with
    quadrilateral elements.
  2. Go to menu point [utilities] = [copy]
  3. A copy window appears:
  • select entities type = Elements
  • Transformation = i.e. Translation
  • select or insert first and second point (that is the sweep path)
  • THEN Do extrude = VOLUMES
Volume elements will be created. In this case hexahedras.
In the same way you can extrude a surface (geo) to a volume (geo) and
then mesh the volume.
I hope, it solve your problem.
Rafael
On Wed, 2004-10-13 at 00:09, Henry Liu wrote:
Hi, everyone
mesh.
thanks
Henry Liu
Henry Liu
The file ‘volume_bad’ has duplicated four lines: 6 - 20, and 7 - 29, then
cannot closed a volume.
(can see the entities number with View-Label-All)
You can see also graphically this problem with: Utilities-Draw
higher-Lines
To solve it, can collapse duplicated (not shared) entities:
Utilities-Collapse-Model
Then can create the volume, without problems, selecting all surfaces as
boundary.
Sent: Tuesday, October 12, 2004 5:09 PM
Subject: [GiDlist] CAN’T generate volume mesh
Hi, everyone
mesh.
thanks
Henry Liu
Henry Liu
