Hi everyone,
when i use the option " calculation file", is the template file automatically written?
So, could i see the “template file” section only to know what the meaning of every field is?
or do i learn how to written a template file because this is necessary “a priori”?
calogero
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030806/cbe14f4b/attachment.htm
The template has to be created by the user. The “Export - calculation file”
option just write a data file with the information required by the template
file.
You can find more detailed information in the GiD help, section
“CUSTOMISATION Template file”. There is a detailed example which describes
step by step how to create this file.
An additional suggestion is to read the Problemtype Tutorial, with a very
easy example describing the whole process to create a new GiD problem type.
You can find it at http://www.gidhome.com/support/su05.subst
J
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de Calogero Fontana
Enviado el: miércoles, 06 de agosto de 2003 11:10
Asunto: [GiDlist] Calculation & template file
Hi everyone,
of every field is?
“a priori”?
calogero
