Hello Mr. Forest,
Thanks to your previous report, we could fix this bug.
A preliminary version with the correction,
will be available in one month, or less.
Meanwhile, i cannot see a way to overcome this error, as it selects the border
with the littlest node number.
Thanks for your help
6.3.2k1
Alexandre Forest wrote:
I have a problem with the new version (6.1.2) of GiD that I did not
experience
with v.5. That is:
When generating a 3D mesh consisting of a box enclosing a wing that is
attached to one of its side, I want to create border graphs of the wing
sections.
In v.5, I would generate some sections cuts, then I was able to select
the
wing section only, and not the square (that was generated by cutting the
wing
and the box enclosing it) that is part of the cut.
In v.6.1.2, it seems that it is impossible to separate the wing section
from
the rest of the cut for the purpose of a border graph.
Can you help?
Alexandre Forest
ETS
