I am trying to create a cylindrical hole using a boolean operation in GID.
I am having a simple cubic geometry (so I have 2 volumes- 1 cube and 1
cylinder which completely lies inside the cube)
[image: Inline image 6][image: Inline image 7]
I am simply using geometry - edit - boolean op. for volumes to subtract
the cylindrical volume from the cubical volume. But, this operation does
not create a cylindrical hole in the cubical domain but instead it’s doing
something very strange like what the right figure shows (with an info
window saying volumes not closed). Is there something I am missing here for
the boolean operation to work in GID?
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141104/87c0b3ce/attachment-0001.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141104/87c0b3ce/attachment-0002.png
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141104/87c0b3ce/attachment-0003.png
Boolean operations are too hard and not very robust. Try to avoid its use in GiD.
You can create easily your model without any boolean operation, e.g. create a square surface with a circular hole, and then use copy with extrusion to create your volume.
Enviado el: miércoles, 5 de noviembre de 2014 0:40
Asunto: [GiDlist] Boolean operations for volumes
I am trying to create a cylindrical hole using a boolean operation in GID. I am having a simple cubic geometry (so I have 2 volumes- 1 cube and 1 cylinder which completely lies inside the cube)
Inline image 6Inline image 7
I am simply using geometry - edit - boolean op. for volumes to subtract the cylindrical volume from the cubical volume. But, this operation does not create a cylindrical hole in the cubical domain but instead it’s doing something very strange like what the right figure shows (with an info window saying volumes not closed). Is there something I am missing here for the boolean operation to work in GID?
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141105/92469fc8/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141105/92469fc8/attachment.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141105/92469fc8/attachment-0001.jpeg
