I’m trying to do a parametric analisys with Tochnog and Gid as pre-postprocessor. As I have to make a high number of models very similar between them (just changing a geometric parameter each time), I woud like to know wether is possible to introduce variables in batch files, in the sense Tochnog allows.
The definition of the variables can be done in Tochnog with a start define … end define or start arithmetic … end arithmetic but I would like to mesh the model inside Gid if possible.
The final goal in the analisys would be to write a (big?) batch file so that invoking Gid all the models within the same family would be generated and meshed.
Thanks in advance,
Jesús Torrecilla Pinero.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011021/5998c5c9/attachment.htm
