[GiDlist] batch file
Hi all,
I have a question in regards to writing a batch file. Is it possible to define and declare a variable in a batch file. For example:
Set a_x = 5.0
Set a_z = 2.0
Geometry create point
%a_x, 0.0,% a_z
Escape escape
Peter
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141028/255000a7/attachment.htm
No, the batch file is not a programming language, is only a sequence of GiD
process keyword commands.
To do things like this you must create a Tcl prodedure that send ‘process
commands’ to GiD with GiD_Process,
e.g.
proc create_point { x z } {
set y 0.0
GiD_Process Geometry Create Point $x $y $z
create_point 5.0 2.0
Or you can create the .bch file with some external program where everything
has been replaced to the final GiD process commands
Geometry Create Point 5.0 0.0 2.0
(this final .bch file could be created somehow based on some kind of
template evaluated by your external program)
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Geißler, Peter
Enviado el: martes, 28 de octubre de 2014 11:23
Asunto: [GiDlist] batch file
Hi all,
Set a_x = 5.0
Set a_z = 2.0
%a_x, 0.0,% a_z
Escape escape
Peter
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141028/c360136a/attachment.htm
