A batch file cannot have a special name or extension.
The valid commands in a batch are exactly the same names that appear in the
right button bar
(select Utilities-Graphical-Toolbar to visualize these Right Buttons)
Note: when select Undo, it appear the sequence of used commands. This is a
sample of bath file.
The user can also automatically save the commands in a bachfile (see
preferences, Write batch file)
To load a batch, use Files-Read Batch file (or Utilities-Graphical-Read
Batch Window to execute step by step the file)
From: “CASARES MALDONADO ALEJANDRO” ACASARES at puceuio.puce.edu.ec
Sent: Monday, July 09, 2001 8:06 PM
Subject: [ GiDlist ] Batch data reading in GID
High to all:
Which is the better way of reading GID data for a new project (specially
geometry data) without typing it in interactive mode? Perhaps "Reading
batch
file"?. But what is the content of that file?, Does it have some special
name or extension? Are there some special commands for doing so? I have
looked in the reference manual, without finding a clear answer.
Alejandro Casares
Hi;
i imported parasolid model in GID 6.1.4 with succesful, and it give me one
volume, the geometry, it seems all right, but i want to mesh, it mesh all
surfaces with succes, but it can not mesh the volume because it does not find
the point, what can i do? thanks
Please, send us the sample file (parasolid and gid files) to check it.
Note: send directly to escolano at cimne.upc.es
Sent: Monday, July 30, 2001 7:12 PM
Subject: [ GiDlist ] parasolid import
Hi;
find
a lot of thanks Enrique, but i got to mesh the model.
thanks again
Hi;
find
