[GiDlist] .bas file problems
Thanks again for the prompt reply, unfortunately what you say is only part
of the answer. It appears that none of the variables a1 b1 m1 etc are
treated correctly. If I replace a1 by aa b1 by bb etc everything goes as
expected.
Maybe best not to have a mixture of alpha and numeric for variable manes?
Mark
-----Original Message-----
Sent: 27 May 2002 21:32
Subject: Re: [GiDlist] .bas file problems
This is bug of GiD parsing the condition if(z=e1)
the variable e1 is evaluated incorrectly as a exponential number 0e1, not
as the variable named e1,
and the result is only true if z=0
This bug is corrected for the next GiD version.
You can avoid this bug if not use names as e"number" (e1, e206, etc) for the
variables.
Thanks for your report.
From: “Mark Smith” mailto:mark.smith at linx.co.uk mark.smith at linx.co.uk
To: “Gidlist (E-mail)” mailto:gidlist at gatxan.cimne.upc.es
Sent: Friday, May 24, 2002 4:38 PM
Subject: [GiDlist] .bas file problems
Win98 GiD 6.3.0b
Dear GiD team & users
I’m having some problems with unexpected behaviour of *if *else *elseif
etc
can you have a look at the attached code and tell me why the output is not
as expected
rgbtest.bas = sample code
rgb.txt = output of .bas code
expected.txt what I expect the output to be ( done in mathcad)
expected.txt RGBtest.bas rgb.txt
Mark
+44 (0)1480302100
_http://www.linx.co.uk/ http://www.linx.co.uk/_
person.
business of Linx shall be understood as neither given nor endorsed by
Linx.
+44 (0)1480302100
person.
With GiD 7.0-Beta2 only fail case with variable name e"number",
but with your GiD 6.3.0b version there is some problem more with the
varnames.
Sent: Tuesday, May 28, 2002 11:05 AM
Subject: RE: [GiDlist] .bas file problems
expected.
Mark
the
variables.
Win98 GiD 6.3.0b
etc
not
as expected
Mark
+44 (0)1480302100
received
person.
Linx.
+44 (0)1480302100
_http://www.linx.co.uk/_
person.
Linx.
