[ GiDlist ] bad designation of axes
In Gid 6.1.1, when i want to divide a nurbs surface, the 2 axes are designated by u whereas they should be designated by u and v. Do you have a correction for this problem?
Thank you.
Patrick Chevalier.
Tél : 08 36 69 00 21
There are really an ‘u’ and a ‘v’ but the look almost the same.
For a better distinction we will change the colors for the ‘u’ and ‘v’ axis,
and try another font types.
My purpose is to use the “read surface mesh” option and transfert MESH
format into IGES format in order to compare
finite element geometry after distorsions with real geometry.
But I cannot create an IGES file from surface mesh data. In fact when I
read a surface mesh,
the mesh is well converted in points, lines and surfaces geometry entities,
but I can export it immediately in IGES format.
When I try, the IGES file is empty. The solution I have found (todate) is
to delete all the surfaces and create again all the surfaces, but in this
case
the complexity of the geometry (about 15000 surfaces) leads to many holes
on the surface, then it is impossible to generate
the volume (solid).
Do you have another solution to bypass this problem, thank you very much in
advance for your help.
Charles Aliaga.
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify
the system manager.
