[GiDlist] About ".central.s info gendata"
What about acces to others data sets: Conditions, Materials. The
_GidAccessValue function seems to be have acces to more information
than the user interface fonctions GIdUtils::GetProblemDataValue and
GidUtils::GetCurrentIntervalDataValue.
Mihai TEODORESCU
Email: mihai.teodorescu at prevost-industries.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030319/0d7511a9/attachment.htm
Dear All,
I am looking for a Tcl procedure to execute a problem_type.win.bat.
I wish to reproduce the same command as GID, that means:
problem_type.win.bat project_name project_name_directory
problem_type_directory
and now, don’t.
For example I execute the Execute command from the InitGIDProject
procedure something like this :
proc InitGIDProject { dir } {
The Execute Tcl command is called here
source $dir/scripts/Execute.tcl
the variable GidRepertoire take the value of the
problem_type_directory directory
set GidRepertoire $dir
Execute GidRepertoire
with:
proc Execute {repertoire} {
The name of the executable problem_type.win.bat
set executable “IDRA.win.bat”
set exttrans “/”
set aa [.central.s info Project]
set ProblemType [lindex $aa 0]
set ProjectName [lindex $aa 1]
set ProjectName [file root $ProjectName]
set repertoire [file native $repertoire]
the argument %1
set basename [file tail $ProjectName]
the argument %2
set directory $ProjectName.gid
the argument %3 corresponds to $repertoire
append script $repertoire$exttrans$executable
exec $script "$basename" "$directory" "$repertoire" &
NUL: &
This procedure doesn’t work here because the directory names are written
as:
C:\Program Files\GID\GID7.2\problemtypes\IDRA.gid
and should be written as:
C:\PROGRA~1\GID\GID7.2\PROBLE~1\IDRA.GID
Can somebody help me to use the right Tcl command.
Thank you in advance,
G.W.R. Geis
To run a bat file is needed call a interpreter command as “command.com” for
Win9x or “cmd.exe” of WinNT/2000
You can use auto_execok to write a “system independent” command (it set
automatically the appropiate paht
and cmd.exe or command.com)
exec [auto_execok $batfile]
You can also use command.exe provided with GiD to avoid some limitations of
the
Windows command.com and cmd.exe (size of parameters with small limit, etc)
See GiD help on Tcl/Tk extension-Using EXEC in GiD
exec [[file join $GIDDEFAULT command.exe] $batfile]
To: “GID” GiDlist at gatxan.cimne.upc.es
Sent: Thursday, March 20, 2003 4:56 PM
Subject: [GiDlist] Finding a Tcl procedure to execute *.win.bat
Dear All,
and now, don’t.
# The Execute Tcl command is called here
# the variable GidRepertoire take the value of the
with:
# The name of the executable problem_type.win.bat
set exttrans “/”
# the argument %1
# the argument %2
# the argument %3 corresponds to $repertoire
NUL: &
as:
G.W.R. Geis
Thank you Enrique for your response, neverthless, my problem is not exactly
this one and I had surely not well explained it !
I wish execute an external program without generating a mesh (that means, it is
not possible to use a problem_type.win.bat).
So, I’d execute an external program called PROGRAM.exe, for example.
This program needs the name of the problem type directory and the name of the
current project, which will be recognized as argument %1 and %2 by PROGRAM.exe
For the moment I use this Tcl command:
exec PROGRAM.exe $problem_type_directory $current_project_name &
NUL: &
where :
$problem_type_directory is the variable containing the name of the
problem typedirectory which is here: C:\Program
and
$problem_type_directory is the variable containing C:\Documents and
Setting\IDRA\test.gid
But this doesn’t work, because the directories names are not given by their
Window 3.1 name (there is blank space in the name).
Could you tell me if it is the good way to execute without meshing or if there
is an other good solution.
Thank you if you have a response.
G.W.R. Geis
the
Dear All,
and now, don’t.
with:
set exttrans “/”
# the argument %1
# the argument %2
NUL: &
as:
G.W.R. Geis
Dear All,
OK, I have found the response to my question (great!)
To execute an external program.bat using arguments:
InitGIDProject
InsertMenuOption “Calculate” “Run IDRA” 5 {RunExternalProgram $dir} “PRE”
“insert”
UpdateMenus
End InitGIDProject
proc IdraIsRunning {repertoire} {
RunExternalProgram
set exttrans “\”
set nothing “”
set executable “ExternalProgram.exe”
Corresponding to GID’s %1
set basenameFF [file native $basename]
Corresponding to GID’s %2
set directoryFF [file native $directory]
set directoryFFF [file attributes $directoryFF -shortname]
set directoryFFF [file native $directoryFFF]
Corresponding to GID’s %3
set repertoireFF [file native $repertoire]
set repertoireFFF [file attributes $repertoireFF -shortname]
set repertoireFFF [file native $repertoireFFF]
Script to execute
append script $repertoireFF$exttrans$executable
exec $script $basenameFF $directoryFFF $repertoireFFF & NUL: &
End RunExternalProgram
Ouf !
G.W.R. Geis
NUL: &
where :
and
G.W.R. Geis
the
Dear All,
and now, don’t.
with:
set exttrans “/”
# the argument %1
# the argument %2
NUL: &
as:
G.W.R. Geis
I noticed in GID 7.2 that the POSTPROCESS doesn’t read the problem
type.flavia.msh file,
created from a problem type problem type.
When the POSTPROCESS window is called, only the problem type.msh is
read in GID 7.2, what it is not the case in the GID 7.1.
G.W.R. Geis
Hola Miguel.
Parece que tiene razón esta persona
Puedes mirar de corregirlo.
Sent: Friday, March 21, 2003 1:50 PM
Subject: [GiDlist] Problem with *.flavia.msh in GID 7.2
G.W.R. Geis
Yes, i found the problem. will be solved for the next beta.
in the mean time you can rename your .flavia.msh /.flavia.res
to .post.msh /.post.res.
Enrique Escolano wrote:
Hola Miguel.
G.W.R. Geis
It seems a bug to correct. But, if it exists the results file
(.flavia.res), then if exist (.flavia.msh) is also
readed instead the preprocess mesh.
Thanks for your bug report
G.W.R. Geis
