Dear,sir/madam,Enrique Escolano
There is a sample in attached files. You should tanslate to Mesh view in Gid When you open the files of “sa.gid”,And I create a bach file,butTHe model which you import bach files are better than the sa.gid,but there are some wrong on the boundary.
BTW,I will get different model when i import sa.bch? Why?
Thanks for your help
======= 2003-07-24 14:53:00 You wrote:=======
Send us a small sample and the procedure to obtain this error.
Note: If you use a version previous to 7.4.2-b, must update (from the web
section download beta versions). Some bugs can be corrected.
Sent: Thursday, July 24, 2003 3:12 AM
Subject: Re: Re: [GiDlist] A question about Mesh extrusion
Dear,Enrique Escolano
There are some error in this way when I use Offest.Can you help me.
======= 2003-07-22 20:26:00 You wrote:=======
This feature is also available in previous 7.x versions.
Select mesh view, and then open the “copy window”.
Can extrude elements by translation, rotation, etc.
Sent: Tuesday, July 22, 2003 11:00 AM
Subject: [GiDlist] A question about Mesh extrusion
Dear GiD teams
There are a new availab in GID 7.4.2b of Mesh extrusion,But I can’t
find it in Copy windows! Can you help me?
Fegen software Co.,Ltd
_http://www.fegensoft.com/english_
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-22
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-24
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-25
