[GiDlist] a bug of res
Hi
There have a question about the files of res.You could find a res files in
attched files. You can use Gid to read it in postpress. The “ell” is a
vector,but you cannot read it in gid,but if you change the name of “ell” to
“ella” than you can find the right result.Can you tell me why??
Yours
edodo
http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021029/938a7bc8/attachment.obj
hello,
yes it is a malfunction:
when displaying vector result ‘ell’ gid looks for the first results
which begins with ‘ell…’, and finds ‘ells1’ which is not a vector
and can not be drawn.
the problem will be corrected for the next version.
in the meantime you can use self excluding names.
fea wrote:
Hi
Yours
edodo
http://www.eyou.com
res.rar Type: unspecified type (application/octet-stream)
Encoding: base64
