[GiDlist] a bug of 7.0
HI all
I found a bug in gid7.0 beta,When I use sweep to creat a body,but it do
wrong,i have attach it in attach files.
I want to get some advie form you about *.res files. Now we have a
question. We want to put all the rest in a block,but we have a trouble,we must
to change a keyword to put in *.res,example Vector,matrix and so on,but we
couldn’t find a keyword for my question. My problem have eight numerical
values, how to do?
edodo
Beijing FEGENSOFT
http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020529/cebdae8c/attachment.obj
The function sweep is very recent, reason why they can appear some problems,
Thanks to send its example to us
( to avoid possible virus it is best to send a compressed file that a
executable one)
As far as the postprocess format question, its case with seven values
must be considered as seven independent scalar values.
---- Original Message -----
To: GiDlist at gatxan.cimne.upc.es
Sent: Wednesday, May 29, 2002 11:41 AM
Subject: [GiDlist] a bug of 7.0
HI all
do
must
values, how to do?
edodo
Beijing FEGENSOFT
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
Hi there,
I am trying to write a postprocess module inside Tochnog for GiD (Tochnog
did, but in the old format). The problem is that even I can write the mesh
correctly, I cannot write the Results. I tried to study the file from
Rambshell example, but it has many fields that are not in the documentation,
so I don’t know what are they for.
I attach my mesh and result files (Note: tube1.flavia.msh is not the file
directly produced, but one lighty touched by hand).
Another thing, when you write a Vector result, two or three results are
expected depending on the dimension of the mesh. What if you want to put
three variables in a vector even in a plane mesh? (for example, in a plane
stress problem, you have a transversal movement depending on the thickness;
I know that is inmediate to obtain it, but by now you cannot write this
result directly).
Best,
Jesús Torrecilla
Área de Conocimiento de Ingeniería de la Construcción.
Universidad de Extremadura
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020612/493c7b7d/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020612/493c7b7d/attachment-0001.obj
Your files are ok.
NOTE: To read this new postprocess format is required GiD version 6.1.4b or
higher.
Download the last GiD beta version from the web http://gid.cimne.com
This format is documented inside the help of each version
(you can see also the online manual directly from the web)
You can write a 3D vector result for a 2D mesh (really the 2D mesh is stored
as 3D with z=0)
Sent: Friday, March 22, 2002 10:33 AM
Subject: [GiDlist] About PostProcessing again
Hi there,
documentation,
thickness;
result directly).
Best,
Jesús Torrecilla
