GiD failing to launch under Debian 9 Stretch
I recently installed GiD 13.0.4 on my linux desktop, running Debian 9 Stretch, and GiD fails to launch when executing the command ./gid. I receive the error message:
Configuring GiD for GLX Rendering
Illegal instruction
When running ./gid.exe I receive the error message:
./gid.exe: error while loading shared libraries: libobjarray_64.so: cannot open shared object file: No such file or directory
This file, in fact, does exist in the directory GiDx64/13.0.4/scripts/objarray, but cannot be found.
Please advise on how to fix this - I have already purchased a USB license for GiD, and expect it to work on my linux system. I have an older video card with a Radeon HD 7970 chip, is this related to the problem?
In Linux/Mac os X you must not directly run gid.exe but the script ‘gid’ or ‘gidx’ that set some environment variables prior to run gid.exe
In your case
./gid
is raising some error related to the graphic card its driver to use OpenGL acceleration
you can also try with OpenGL by software (mesa) with
./gidx
