GaussPoint
Hi, I am new with GiD. I am trying to import GaussPoint results into my post-process.
I read the information about how to include GP into the res file but I have some issues.
I defined like this :
GiD Post Results File 1.0
GaussPoints “Gauss_Soil” Elemtype Quadrilateral
Number of Gauss Points: 4
Natural Coordinates: internal
End GaussPoints
Result “Stress” “Stress Soil” 1 Matrix OnGaussPoints “Gauss_Soil”
Values
First Question, is the use of “Matrix” appropriate here? I have, for each element, 4 GP with three data on each (XX, YY, XY).
Second Question, what format should I use, if say, I do have 4 analyses?
Something like this? (*The ---- are meant to simulate white space… but when I send the message on the forum the format doesn’t stick and all collapse so I added the — ).
Element GaussPoint XX_Analyses_1 YY_Analyses_1 XY_Analyses_1 XX_Analyses_2 .. etc XY_Analyses_4
1-------------1 --------Values------------Values … etc.
--------------2--------values-----------Values … etc.
--------------3---------Values–…
--------------4---------Values …
2-------------1---------etc.
--------------2
… etc.
If not, how I am suppose to format the data ? Thanks for your precious help! :smiley:
You can avoid to define this block for standard gauss points (like quadrilateral of 4 internal gauss points)
GaussPoints "Gauss_Soil" Elemtype Quadrilateral
End GaussPoints
and simply use the keyword GP_QUADRILATERAL_4
Result “Stress” “Stress Soil” 1 Matrix OnGaussPoints GP_QUADRILATERAL_4
The type of result ‘Matrix’ is appropiated assuming that your mesh is 2D, then only XX, YY, XY of the 2x2 symmetric matrix are required, with this syntax:
Result "Stress" "Stress Soil" 1 Matrix OnGaussPoints GP_QUADRILATERAL_4
Values
element_id xx_g1 yy_g1 xy_g1
                 xx_g2 yy_g2 xy_g2
                 xx_g4 yy_g4 xy_g4
                 xx_g2 yy_g2 xy_g2
                 xx_g4 yy_g4 xy_g4
End values
If to you have four analyis you could repeat the block, using another time step
Result “Stress” “Stress Soil” 2 Matrix OnGaussPoints GP_QUADRILATERAL_4
Result “Stress” “Stress Soil” 4 Matrix OnGaussPoints GP_QUADRILATERAL_4
or using another analisis name (“Stress Soil”) for each analysis.
the extra spaces between items doesn’t matter in ASCII format.
It exists a binary format, in order to write it we provide the ‘GiDPost library’ that allow write both formats (ASCII or compressed binary)
http://www.gidhome.com/gid-plus/tools/476/gidpost
The binary format is interesting for big data files (is smaller and faster to be read that using ASCII)
