Hi Enrique,
In this mail you give some information about the side of elements. I am
interested in choosing side of element. I tried to figure out how I can do
that but I always encounter a problem choosing the side on the mesh figure.
Actually I want to get an output which contains side and its element. I could
do the sets form nodes and elements using condition tool. But i could not get
the side set from there.
Can I choose the element sides on the mesh figure in the GID interface to
define sets or any other conditions on it.
----- Forwarded message from Enrique Escolano escolano at cimne.upc.es -----
Date: Mon, 10 Nov 2003 11:57:34 +0100
Subject: Re: [GiDlist] is possible to get the every side of ele
This face elements are implicitly defined by the element connectivities, not
exists explicit inside GiD
The implicit GiD local numeration of the element faces are:
Triangle: 12 23 31
Quadrilateral: 12 23 34 41
Tetrahedra: 123 243 341 421
Hexahedra: 1234 1562 2673 3784 1485 5876
Your code must enumerate this faces, for example, if your code names A,B,C,
the three faces of a triangle, then can use some as:TRIANGLE FACES:
Face A: *ElemsConec(1,int) *ElemsConec(2,int)
Face B: *ElemsConec(2,int) *ElemsConec(3,int)
Face C: *ElemsConec(3,int) *ElemsConec(1,int)
Also, if you have a condition over a face of a triangle (a edge), you can
identify the implicit face A B or C with globalnodes
*Set elems(triangle)
*Set Cond Line_Face_Load *elems
*loop elems *OnlyInCond
*if(GlobalNodes(1,int)==ElemsConec(1,int))
FACE A
*elseif(GlobalNodes(1,int)==ElemsConec(2,int))
FACE B
*else
FACE C
*endif
*end elems
Or more simple, using the localnodes command
*if(LocalNodes(1,int)==1)
FACE A
*elseif(LocalNodes(1,int)==2)
FACE B
*else
FACE C
*endif
*end elems
Sent: Saturday, November 08, 2003 10:39 AM
Subject: [GiDlist] is possible to get the every side of ele
hi,GID group,
when i use GID, i want to get the information about the side of each
elements. By the command GlobalNodes, after I applied some condition to some
element, I only can get the out-side face of element. are there any way to get
the every side of each element? include the side of internal element. for
example, I want to get the all out-side face of one layer element. how can i
do?
regards
----- End forwarded message -----
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031111/0a00e101/attachment.txt
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031111/0a00e101/attachment.htm
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031111/0a00e101/attachment.gif
