Fw: [GiDlist] ?? Warning: This problemtype must be updated f
Ignote this message,it’s a small bug of the last 7.4.6 GiD version, =
related with translation. It’s corrected for the next beta.
In other hand, your problemtype is not ready to work with GiD if the =
language is not english.=20
To be compatible with other languages, the standard GiD menu name must =
be enclosed with [_ “”]. (This _ is a function to provide the translated =
sentence for the current language), for example you must use:
RemoveMenuOption [_ “Help”] [_ “Tutorials”] “PRE”
To: “GIDliste” gidlist at gatxan.cimne.upc.es
Sent: Wednesday, March 24, 2004 12:54 PM
Subject: [GiDlist] ?? Warning: This problemtype must be updated for
translation
in my customization, I used the command :
RemoveMenuOption “Help” “Customization Help” “PRE”
to remove the Customization Help into the Help menu of GID.
With GID version 7.2, there was no problem, but now, with 7.4.6b
version, a message appears in the info bar :
Warning: This problemtype must be updated for translation
I wish this message doesn’t appear. Is-it possible ? Is there a command
to remove option menu that is common to the 7.2 and 7.4.6b versions ?
Thank you in advance,
G.W.R.Geis
1 2 3 . . .
Reparaciones, servicios a domicilio, empresas, profesionales… Todo en la
guía telefónica de QDQ. http://qdq.msn.es/msn.cfm
