Experiencing Error in Consolidation Joint Element
I am trying to build and rerun Code)Bright tutorial examples relevant to joint modeling: Consolidation Joint Element and Shear Hydraulic Test. In both example I am experiencing the error “No results found: definitions for 4 gauss points read.” when I try to go post-process and see the results. There is not any results as well. I attached both projects in case you want to take a look at the files. Could you let me know what the problem is in my model?
joint01.gid.zip (62.8 KB)
consolid.gid.zip (81.6 KB)
