Hi there,
I am using code bright for my research on THM process in soil pile interaction but I am getting some errors while using external load on THM coupling. I am facing the problem of ‘EOF in line 1’, could you please help me to get solution of this problem.
Hi Kevin!
The error EOF too early is not an specific error that can give me any clue about what’s wrong with your model. All that I can tell you is that you have some basic errors in your Code_Bright project. Tipically the problem would be about your boundary or initial conditions. Also, check out the name of your project: if you have any blank spaces in the name, it might cause a reading problem for the code.
Hope it helps.
Alfonso
