EOF too early
Hi there,
I am using code bright for my research on THM process in soil pile interaction but I am getting some errors while using external load on THM coupling. I am facing the problem of ‘EOF in line 1’, could you please help me to get solution of this problem.
Thank you in advance
THM practice.gid.zip (34.5 KB)
THM Coupling Practice.gid.zip (2.7 MB)
THM Coupling Practice with load on pile.gid.zip (131 KB)
Hi khagendra!
As I expected, it seems you still need a lot of practice with the tutorials. I have take a look to your first problem and found a couple of mistakes. For example, you haven’t set an initial porosity and in the boundary conditions it seems you want to prescribe the displacements, but you use a -1, and the only possibilities are 0 -not prescribed- or 1 -prescribed.
Besides, I strongly recommend you to don’t use spaces in the name of your problem. You can use slashes (_) instead, for example.
Best wishes,
Alfonso
