Hi.
I would like to know how to create a folder inside the model’s folder to put the .post.msh and .post.res files. Also, when i change pre → post inside GiD, how GiD will know the new directory of the .post.msh and .post.res files?
Hi.
GiD won’t find your files if you move them to another sub-folder, it expect these exact names
.post.res
and .post.mesh (if required because is different of the preprocess mesh)
If do you have multiple result or mesh files, e.g. a mesh by time step, or splitted partitions of the mesh for parallel simulation, then can use as alternative a list file
.post.lst
that has a header, and then the list of relative filenames of results to be read, then is common to be stored in a subfolder.
