I get this error: Error creating rectangle: Corners must be in same z plane
I was thinking about creating points, lines and surface directly, but is there an easy way to create a rectangle in any different plane from z by using GiD_Process or similar?
A rectangle in 3D is not well defined specifying only two opposite corners !!
the function
GiD_Process Mescape Geometry Create Object Rectangle <opposite_corner>
expects the corners in the same z plane. It could be at z=0.0 (as usual clicking in screen)
or in a different z, like the plane z=2.0
e.g: this is a valid definition:
GiD_Process Mescape Geometry Create Object Rectangle 0,0,2.0 0,1,2.0 Mescape
In general, as Anna pointed, you must create a geometrical surface creating its points, its lines, and then the surface
Note: you can create entities with GiD_Processs and then GiD keywords,
or using the direct GiD-Tcl command
GiD_Geometry
see GiD Help on customization, Tcl and Tk
Note: developers have more control with Tcl commands that with ‘GiD_Process’ commands
