I use gid v.14 version. I checked that the SAFIR works properly but after calculation in gid, I take the following error that (I think so) gid cannot convert .DAT file to .IN file that will be used by SAFIR. SAFIR developers said that there might be a problem related with gid since it cannot create a .IN file for SAFIR.
"Process has finished with errors
“No .in thermal input file for SAFIR has been created.”
“No .flavia.res file or results in flavia.res found”
“No .out file or results in .out-file found”
and output info created by gid says:
GiD started Data-converter .DAT to .IN
Safir started .tem-run, IN-file rc30x30x
SAFIR version 2016.c.0 is running.
Please type “FILENAME” of “FILENAME.IN” : ERROR IN THE OPENING OF rc30x30x
It seems as if this file is not present.
Type the file name again, or type EXIT to stop SAFIR.
Please type “FILENAME” of “FILENAME.IN” : Safir finished .tem-run
Error in Thermal2dres, File rc30x30x.out not found.Postprocessor Data generated
Thank you in advance.
Ugur
