Can OpenSeeS add-on be added to GiD USB
Dear all,
Can OpenSeeS add-on be added or Installed to GiD USB?
Arman
What GiD USB mean?
GiD could be registered for a USB memory stick, and then it run professionally in the machine where the memory stick is plugged.
GiD-OpenSeeS is a problemype that customize GiD for OpenSeeS uses.
Problemtypes must be located inside the \problemtypes GiD folder (or a direct access to the true location)
GiD and its problemtypes could be located in the place the user wants, usually its hard-disc, but also could be copied in a memory stick
OpenSees and GiD+OpenSees interface (problemtype) are completely free and can be installed just after the installation of GiD. Check gidopensees.rclab.civil.auth.gr for the new update v2.0.0 on 8 May 2017.
