Hello, is it possible to define break lines to constrain the generation of the mesh ? the mesh triangles should not intersect this line. Thanks
The way to force a surface mesh to be ‘constrained’ by a line mesh is to include that line into the geometrical definition of the surface. The line should be part of the contour of the surface. In case the line is not, you should divide the surface usinga path of lines containing the required line, for instance.
That’s what I thought but I was hoping that there was a simpler solution than cutting on the surface. Thank you
