Hi, I have a problem under MS Windows. Files attached.
- When I run GiD as batch with ‘gid_offscreen -n -offscreen 1000x1000 -b GidPrintBatch.bch’ the generated mesh.jpeg is an empty file.
- When I start GiD and then run the batch file with ‘Utilities’ - ‘Tools’ - ‘Read batch file’ the generated mesh.jpeg is not empty (it contains a picture of the mesh)
Under Linux it goes ok both in batch mode and interactive mode. Help. Thank you.
test.zip (1.79 KB)
