About Mesh and normal to the elements
If you want to write custom information, you should use some of the commands that allow do it.
as you said
  1. a .bas template (but template features are also very limited to few commands)
  2. a .tcl scripting (asking information to GiD and doing what you want with this data without restrictions)
    e.g can ask data of GiD mesh with GiD-Tcl commands like
set element_normal [GiD_Mesh get element $element_id normal]
set triangle_ids [GiD_Mesh list -element_type {triangle} element]
In practice only mean to add to your problemtype another file with few lines of code.
e.g. a normals.bas of about 4 lines of .bas commands like this
*set elems(triangle)
*loop elems
*ElemsNum *ElemsNormal
*end elems
Do you have two solutions, but you don’t want to use these solution, I don’t understand it.
