Element 1808's volume <=0
Posted: Wed Jan 15, 2025 10:45 am
Before any calculations are performed, I get the following error after pressing the calculate button: Element 1808's volume <=0; stop
However, if I examine the model, I see that element 1808 seems to have a surface. Since it's a 2D model, I'm not sure about a volume.
A portion of the model was obtained by copying its left portion (using the "Mirrorâ€Â" option). Could this be the cause of the negative volume of the elements in the right section?
Do you have any suggestions on how to address this issue or identify its root cause?
Thanks a lot!
Thanks a lot!
