Black screen when creating a geometry
shirleysea
Post by shirleysea »
I installed GID16. But when I tried to create a geometry, the window turned to black screen.
Is there anyone having the same issue? How can I solved it?
Re: Black screen when creating a geometry
First try to reset your user preferences,
https://gidsimulation.atlassian.net/wik ... references
Probably is a graphic card issue
- Update your graphic card drivers
- Check that you are really using the graphic card that you want, in case of have more than one
- Try with OpenGL by software
https://gidsimulation.atlassian.net/wik ... MS+Windows
- In windows try the Mesa library version (alternative to OpenGL), starting <GiD>/gid_offscreen.vbs
