[GiDlist] Using different kinds of Gauss points
Posted: Thu Nov 19, 2009 10:04 pm
Dear all:
Can you help me the following problem?
In result file, project.flavia.res, I use 2 different kinds of gauss
quadrature points. Particularly, one gauss quadrature point and three gauss
quadrature points for two groups of triangular elements. As I view results
in postprocess of GiD I can separately view results of each group of
elements. Can I view both of them at the same time?
I attached here the result of my problem.
Thank you in advance and I am looking forward to hearing from you as you
can.
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091119/31333e93/attachment-0001.htm
Type: application/pdf
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091119/31333e93/attachment-0001.pdf
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091119/31333e93/attachment-0001.obj
Type: model/mesh
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091119/31333e93/attachment-0001.msh
can.
Thanh
Type: model/mesh
