[GiDlist] Problems with GiD license
fsalazar at cimne.upc.edu
Post by fsalazar at cimne.upc.edu »
Good morning, GiD team.
I'm working in LINUX Opensuse, with the latest beta version of GiD.
GiD used to work perfectly, but I had another problem: internet didn't
work in LINUX. In order to solve this problem, I checked the
configuration of net devices in Yast. Comparing my configuration with
the one used by a friend with the same version of Opensuse, we
realized that there was a difference in "Net card
configuration/General/Activate device". I had the option "Manually",
and he had "During boot". I changed this option, and internet started
to work. You must be wondering what does Gid have to do with this.
Well, the problem is that after changing this option, GiD didn't
recognize the license (I use a portable USB one). First, I tried
asking for a conventional password to register GiD in the professional
version, but it didn´t work. So I tried to undo the change in
the configuration of the net devices, turning it to "Manually" again,
and the problem was solved.
Now I must choose between using GiD and internet, which is quite
annoying. Any suggestion?
Thanks in advance.
Fernando Salazar González
CIMNE
Paseo Gral Martínez Campos, 41, 9º Izq.
Madrid 28010.
Tel. +34 91 319 13 59
Tel. +34 610 234 477
Fax: +34 91 319 13 59
www.cimne.com
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se
registrarán enun fichero para facilitar la gestión de
las comunicaciones de CIMNE. Se pueden ejercitar los derechos de
acceso, rectificación, cancelación y oposición
por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran
Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona,
España.
AVIS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge
es registraran en un fitxer per facilitar la gestió de les
comunicacions del CIMNE. Es poden exercir els drets d'accés,
rectificació, cancel·lació i oposició, per
escrit a les nostres oficines del CIMNE, Gran Capità s/n,
Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
confidentially andstored in a file property of CIMNE in order to
manage corporate communications. You may exercise the right of access,
Capitán, Edificio C1 - Campus Norte UPC, 08034 Barcelona,
Spain.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091023/0a3ab36a/attachment.htm
Post by miguel »
the behavior you are explaining is very strange. My guess is that when YaST configures the network, somehow hassles the usb configuration.
For the local password GiD uses the name of the machine (which can be change by the network configuration) and info of your local hard disk.
But for the USB password, GiD only uses the serial number of the usb memory stick which is read from /proc/bus/usb/devices, and looks for a password file inside the mounted device (if it's not in $GID/scripts folder).
We know about problems with suse distributions, which do not mount automatically the /proc/bus/usb file system, as explained in http://www.gidhome.com/support_team/faq_toc/faq7.html#Solve%20problems%3EGiD%20doesn%27t%20detect%20the%20USB%20memory%20stick
¿Can you check if the file /proc/bus/usb/devices still exists when you configure your network?
¿Does you usb device appear in the list when you GiD--Help--register?
Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
De: gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu [mailto:gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de fsalazar at cimne.upc.edu
Enviado el: viernes, 23 de octubre de 2009 10:55
Asunto: [GiDlist] Problems with GiD license
I'm working in LINUX Opensuse, with the latest beta version of GiD. GiD used to work perfectly, but I had another problem: internet didn't work in LINUX. In order to solve this problem, I checked the configuration of net devices in Yast. Comparing my configuration with the one used by a friend with the same version of Opensuse, we realized that there was a difference in "Net card configuration/General/Activate device". I had the option "Manually", and he had "During boot". I changed this option, and internet started to work. You must be wondering what does Gid have to do with this. Well, the problem is that after changing this option, GiD didn't recognize the license (I use a portable USB one). First, I tried asking for a conventional password to register GiD in the professional version, but it didn´t work. So I tried to undo the change in the configuration of the net devices, turning it to "Manually" again, and the problem was solved.
Now I must choose between using GiD and internet, which is quite annoying. Any suggestion?
Thanks in advance.
CIMNE
Madrid 28010.
www.cimne.com
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán enun fichero para facilitar la gestión de las comunicaciones de CIMNE. Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVIS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d'accés, rectificació, cancel·lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
All personal data contained in this mail will be processed confidentially andstored in a file property of CIMNE in order to manage corporate communications. You may exercise the right of access, rectification, deletion and objection by letter sent to CIMNE, Gran Capitán, Edificio C1 - Campus Norte UPC, 08034 Barcelona, Spain.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091119/637478c2/attachment.htm
