Dear all,
I am using GiD 9.0.2. As I mesh a rectangular plate with nonsymetrical
structured triangular elements, I can not control the hypotenese direction
of the element. It is always from bottom left to top right of a rectangular.
Could you please help me how to modify this hypotenuse direction?
Thank you in advance.
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091009/7c5f26b1/attachment.htm
[GiDlist] control hypotenuse direction of a triangular meshi
You can't control this direction.
You must do some trick, like swap the normal of the surface (but then the elements normal will be also swapped)
Sent: Friday, October 09, 2009 4:39 AM
Subject: [GiDlist] control hypotenuse direction of a triangular meshing
Dear all,
I am using GiD 9.0.2. As I mesh a rectangular plate with nonsymetrical structured triangular elements, I can not control the hypotenese direction of the element. It is always from bottom left to top right of a rectangular. Could you please help me how to modify this hypotenuse direction?
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091019/e19dd27a/attachment.htm
Dear all,
Thanh
