Dear friends at GiD,
I have an IGES file that I would like to import, but the content is nodes and elements only (types 134 and 136). Although my GiD 9.0.4 version won't import it, I see from the online documentation that the beta version of GiD will. Could I be allowed to use it for this purpose, and is it possible to then convert the geometry into a form that can be read by GiD 9.0.4 and other software? Thank you!
Kathy
Kathryn M. Butler, Ph.D.
National Institute of Standards and Technology
Building and Fire Research Laboratory
100 Bureau Drive Stop 8665
Gaithersburg, MD 20899-8665
phone: (301) 975-6673
fax: (301) 975-4052
email: kathryn.butler at nist.govmailto:kathryn.butler at nist.gov
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090912/3c72b55c/attachment.htm
[GiDlist] (no subject)
Dear Kathy,
All GiD 9 versions use the same validation, since you can use any GiD 9
version with the same password that you are already using, specifically the
last beta version GiD9.2.1b
Backward compatibility it's not guarantied, so not all files saved with beta
version could be read with official version but usually it can be done.
Sincerely,
Adrià
_____
AVISO IMPORTANTE
Los datos de carácter personal facilitados están registrados en un fichero
con la finalidad de facilitar la gestión de las comunicaciones de CIMNE.
Puede ejercitar los derechos de acceso, rectificación, cancelación y
oposición mediante petición dirigiéndose a nuestras oficinas en Ed. C1
Campus Norte UPC. Gran Capitán s/n Barcelona
AVIS IMPORTANT
Les dades de caràcter personal facilitades seran registrades en un fitxer
amb la finalitat de facilitar les gestions de les comunicacions de CIMNE.
Pot exercir els drets d'accés, rectificació i cancel·lació, per escrit a les
nostres oficines en Ed. C1 Campus Nord UPC. Gran Capità s/n Barcelona.
IMPORTANT NOTICE
All personal data contained on this mail will be processed confidentially
and registered in a file property of CIMNE., in order to manage corporate
communications. You may exercise the rights of access, rectification,
erasure and object by letter sent to Ed. C1 Campus Norte UPC. Gran Capitán
s/n Barcelona.
_____
De: gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu
[mailto:gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de
Butler, Kathryn Dr.
Enviado el: sábado, 12 de septiembre de 2009 0:29
Asunto: [GiDlist] (no subject)
and elements only (types 134 and 136). Although my GiD 9.0.4 version won’t
Kathy
fax: (301) 975-4052
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090914/2eb1edbb/attachment.htm
Sincerely,
Adrià
_____
AVISO IMPORTANTE
AVIS IMPORTANT
IMPORTANT NOTICE
s/n Barcelona.
_____
Butler, Kathryn Dr.
Kathy
fax: (301) 975-4052
Dear Kathy,
GiD 9.0.4 is also able to read this IGES 134 and 136 entity types,
The mesh of GiD 9.1.x beta versions can be also read by GiD 9.0.x versions, and can be exported to other softwares using some template or 'problem type', like NASTRAN, ABAQUS, LsDyna, Fluent, etc
If you can't read your file, could send (directly to escolano at cimne.upc.edu instead the GiDList) to have a look and try to solve the problems.
Sent: Saturday, September 12, 2009 12:29 AM
Kathy
fax: (301) 975-4052
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090914/f0c23ec1/attachment.htm
Kathy
fax: (301) 975-4052
