[GiDlist] RE: Mac OSX: Assign conditions crash the applicat
Blottman, John B CIV NUWC NWPT
Post by Blottman, John B CIV NUWC NWPT »
I found the same problem. Note that this bug showed up in ver. 9.2.2,
but was not in 9.2.0
John
-----Original Message-----
Message: 1
To: gidlist at gatxan.cimne.upc.edu, gidlist-admin at gatxan.cimne.upc.edu
Date: Thu, 27 Aug 2009 09:22:06 -0500
Subject: [GiDlist] Mac OSX: Assign conditions crash the application
Reply-To: gidlist at gid.cimne.upc.edu
--_e9bd293b-fa48-4113-9107-3b5f6c051829_
Content-Type: multipart/alternative;
boundary="_c3c7b2cd-bf28-42f8-850e-bcd87312284b_"
--_c3c7b2cd-bf28-42f8-850e-bcd87312284b_
Content-Type: text/plain; charset="Windows-1252"
Hi:This is a very weird bug I found recently=2C because I was using this
ut= ility without any problems and suddenly start happening. I've tested
in ano= ther machine with different configurations and the results are
the same. I = though it was something related to my own customized
problem type but I use= an example problem type (cmas2d) and the
problem continues. I also try to = reinstall GiD by deleting the
application bundle from Applications and also= ~/.gidDefaults and then
run the installation package again... no luck :S I guess some recent
system update cause a conflict with GiD :S
-Open an existing GiD file or star a new one creating a Geometry and
select= ing a problem type.-Open the condition window=2C select any
condition and p= ush Assign button.-GiD Crashes!!
I'm attaching the apple report for this particular crash.
GiDlist at gid.cimne.upc.edu
Jesus F Gracia
[GiDlist] Mac OSX: Some other minors bugs related menu conte
Post by Jesus F Gracia »
These are not critical as the one that crashes GiD caused by applying conditions to a model, which I agree with John Blottmam that this problem is only present on version 9.2.2b
Open a existing model causes stop refreshing Problem Type menu, to active it again it is necessary to invocate the open/save as window and click cancel.
After selecting a base unit system in a Problem units windows, the combo menu freezes and there is not way to select another base system. It is necessary to close and reopen the Problem units window.
If you post a new release fixing this bugs, it is possible to test it on Leopard Snow?
Greetings!
_________________________________________________________________
With Windows Live, you can organize, edit, and share your photos.
http://www.microsoft.com/middleeast/windows/windowslive/products/photo-gallery-edit.aspx
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090831/36bab4fb/attachment.htm
[GiDlist] RE: Mac OSX: Some other minors bugs related menu c
Post by miguel »
I’ll try to reproduce the problems you mention, and keep you informed.
Currently I’m developing the Mac version on Mac OS X 10.5.7 and didn’t plan
to upgrade it to 10.6 as nobody I knew uses this latest release of Mac OS X.
Do you have the Leopard Snow (10.6) on your Mac?
Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
_____
De: gidlist-owner at gatxan.cimne.upc.edu.gid.cimne.upc.edu
[mailto:gidlist-owner at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de
Jesus F Gracia
Enviado el: lunes, 31 de agosto de 2009 4:01
Para: gidlist-admin at gatxan.cimne.upc.edu; gidlist at gatxan.cimne.upc.edu
Asunto: Mac OSX: Some other minors bugs related menu contents refreshing
Leopard Snow?
Greetings!
_____
ery-edit.aspx
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090901/b23c7299/attachment.htm
Jesus F Gracia
Hi Miguel:I just a matter of time, it depends on DHL :DI think this week we will have it running, I let you know if I saw any problem in GiD
Greetings
To: jfgracia at hotmail.com; gidlist-admin at gatxan.cimne.upc.edu; gidlist at gatxan.cimne.upc.edu
Subject: RE: Mac OSX: Some other minors bugs related menu contents refreshing
Date: Tue, 1 Sep 2009 10:20:42 +0200
I’ll try to
Currently I’m
developing the Mac version on Mac OS X 10.5.7 and didn’t plan to upgrade
Miguel Pasenau
Miguel
Pasenau
T: +34 3 93 401 74
03
IMPORTANT NOTICE
All personal data contained in this mail will be processed confidentially and
stored in a file property of CIMNE in order to manage corporate communications.
You may exercise the right of access, rectification, deletion and objection by
letter sent to CIMNE, Gran Capitán, Edificio C1 - Campus Norte UPC, 08034 Barcelona, Spain.
De:
[mailto:gidlist-owner at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de Jesus F Gracia
2009 4:01
Para:
and click cancel.
Greetings!
More than messages–check out the rest of the Windows Live™.
http://www.microsoft.com/windows/windowslive/
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090901/5d507a24/attachment.htm
Claudio AC Silva
[GiDlist] Visualization of fields at Tetrahedra Gauss Points
Post by Claudio AC Silva »
I am having problems when trying to visualize fields defined at Gauss Points
of tetrahedra elements if 10 Gauss Points are used (if the results are defined
at 4 Gauss Points of the same tetrahedra, there is no problem). First of all,
the fields at Gauss Points are only shown in "Contour Fill" and not in "Smooth
Contour Fill". Then, if I choose the visualization of any field defined at
Gauss Points in the "Contour Fill" option, GiD closes with segmentation fault.
The same happens if 10 Gauss points are "Given" or "internal".
I am using the last GiD version for Linux 64 and I am attaching two small
examples that cause those problems here. Is it a software bug or my
postprocess files are incorrect?
Thank you in advance,
Claudio
Claudio Alessandro de Carvalho Silva, Dr. Eng. (#329333)
CAE Solutions
Thorus Scisoft - www.thorus-scisoft.com.br
Fone:+55 19 3705-4002
This message is intended solely for the use of its addressee and may contain
privileged or confidential information. If you are not the addressee you
should not distribute, copy or file this message. In this case, please notify
the sender and destroy its contents immediately.
Esta mensagem é para uso exclusivo de seu destinatário e pode conter
informações privilegiadas e confidenciais. Se você não é o destinatário, não
deve distribuir, copiar ou arquivar a mensagem. Neste caso, por favor,
notifique o remetente da mesma e destrua imediatamente a mensagem.
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090904/eddaf75d/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090904/eddaf75d/attachment-0001.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090904/eddaf75d/attachment-0002.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090904/eddaf75d/attachment-0003.obj
Hao Chen
[GiDlist] (no subject)
Post by Hao Chen »
Dear ABEL,
Your explanation is quite clear. It perfectly solve my problem.Thank you very much for your fast reply.
Chen
Dear Chen,
If you want to generate a volume mesh using GiD, you must be in one of these two situations:
- topological closed set of surfaces. In this case, you can create the volume (Geometry-Create-Volume) and generate the mesh (Mesh-Generate).
- a conformal mesh which close a volume (each edge have HigherEntity==2). In this case, you can generate the volume mesh selecting (Mesh-MeshFromBoundary), and selecting all the triangles closing the volume. This option is only available from the Right Buttons (you can set them by clicking 'Utilities-Tools-Toolbars').
If I have understood well, you are not in one of these cases, so you will have to do some work to reach one of these situations.
Kind regards,
ABEL
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán en un fichero para facilitar la gestión de las comunicaciones de CIMNE. Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVÍS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d'accés, rectificació, cancel·lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
De: gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu [mailto:gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de Hao Chen
Enviado el: lunes, 24 de agosto de 2009 8:01
Para: Gid mail list
Asunto: [GiDlist] How to generate volume mesh out of surface mesh
Dear all:
I want to generate tetrahetron mesh of a cubic volume.
Now, I have 3 surface triangle meshes of the cubic. Basing on these meshes, I want to generate volume mesh without changing these 3 facets' mesh.
How can I realize it?
Best regards.
Chen Hao.
Drag n’ drop—Get easy photo sharing with Windows Live™ Photos.
http://www.microsoft.com/windows/windowslive/products/photos.aspx
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090907/99925460/attachment.htm
Hao Chen
Post by Hao Chen »
Dear ABEL and everyone,
I started from some simple cases, for example the rectangle, first mesh it by triangle, and then get the bounday mesh of linear segments. And then use the linear segments to generate the surface mesh. That works perfectly.
But, when I applied it to a little bit complex as a 3D case, some error appeared. Please see the attached msh file. I want to generate 3 rectanglar surface meshes from the linear elements, when I choose one rectangle to generate surface mesh, it said rejected 14037672 elements(must have the same z). I can guarantee each rectangle is on the same plane, and even I turn it into Z plane, it still give the same error.
Chen
Date: Mon, 7 Sep 2009 06:53:24 +0800
Dear ABEL,
Chen
Dear Chen,
Kind regards,
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
IMPORTANT NOTICE
Para: Gid mail list
Dear all:
Best regards.
Chen Hao.
What can you do with the new Windows Live? Find out
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090907/c6322c7a/attachment.htm
Hao Chen
[GiDlist] RE: [GiDlist] How to generate volume mesh out of s
Post by Hao Chen »
But, when I
Chen
Dear ABEL,
Chen
Dear Chen,
(Mesh-Generate).
Kind regards,
ABEL
AVISO IMPORTANTE
Los
AVÍS IMPORTANT
Les
IMPORTANT NOTICE
All
Para: Gid mail list
Dear all:
Now,
Best regards.
Chen Hao.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090907/27fdf5f9/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090907/27fdf5f9/attachment.obj
Ralph Echter
[GiDlist] NURBS FEM postprocessing
Post by Ralph Echter »
Hello to GID support,
I have some question concerning postprocessing/ visualization of NURBS
FEM results.
I have written a small C Code using the preprocessor data of GID (knot
vector data, control point data, weights) for setting up my finite
element code which is so far only plane 2D.
What I obtain from my code are the discrete control point displacement
values. However what I cannot not find in GID is a method of how to plot
those results.
As GID provides me with all required data for defining NURBS basis
functions see above- knot vector data, control point data, weights- it
should normally be not too difficult to create some 2D geometry plot
(parametric plot using NURBS basis functions and control point data) as
well as 2D deformed geometry plots (parametric plot using NURBS basis
functions and control point data+discrete control point displacement
values).
Maybe you have some idea of how to visualize such kind of data .
Thanks in advance
Sincerely
Ralph Echter
Ralph Echter
Institute of Structural Mechanics
University of Stuttgart, Germany
http://www.ibb.uni-stuttgart.de
phone: +49 - 711 - 685 66575
fax: +49 - 711 - 685 66130
mail: echter at ibb.uni-stuttgart.de
Really GiD doesn't has specialized plots for NURBS-FEM results (where the
results are expressed as NURBS parameters: control points, weigths and
knots)
You must transform this kind of representation to a classical mesh results,
where you provide the results on the mesh nodes.
To do it, you need to use an auxiliary mesh (you can generate a GiD mesh)
and associate each node with the parametric coordinates on the NURBS
parametric space of the geometrical source entity.
You need to do the inverse of the parametrization: from a 3D node calculate
the u,v on each source NURBS surface, or directly create a mesh in the u,v
parametric surface space
Then for each result (also displacements) must calculate for each node the
result value (evaluating the NURBS expression of your results for the u,v of
the node)
Note that your NURBS results could be discontinuous between neighbor
surfaces: you will have multiple values for a node belonging to multiple
surfaces, maybe do you want to smooth this result to a single averaged value
Then you can express your results in a classical way, with a GiD .post.msh
mesh file, and a .post.res results file, with nodal results (see GiD help to
know the format of this postprocess results file, or use our GiDPost library
to write them)
If you only want to plot the deformated shape, you can write a .geo GiD
geometry file, with the new geometric NURBS parameters, and you can compare
with the original shape.
to know the .geo ASCII format you can see
http://www.gidhome.com/2004/material/english/12-Geometry%20GiD%20format.pdf
From: "Ralph Echter" echter at ibb.uni-stuttgart.de
Sent: Monday, September 07, 2009 9:27 AM
Subject: [GiDlist] NURBS FEM postprocessing
I have some question concerning postprocessing/ visualization of NURBS FEM
results.
vector data, control point data, weights) for setting up my finite element
those results.
values).
Thanks in advance
Sincerely
Ralph Echter
Ralph Echter
