Quadratic tetrahedral elements node order.
Posted: Sat Nov 18, 2023 3:09 pm
Dear all,
I have already generated a 3d solid mesh using quadratic tetrahedral elements. I did extract the .txt file and imported directly into DIANA FEM software. However, it seems that the node order definition of each element [node1, node2, node3,...,node10] is not already compatible with the order definition expected in DiANA (see the image below). Is it possible to redefine node order within GiD?
Thanks in advance!
Thanks in advance!
