It is possible to create boundary mesh only for one layer?
Posted: Thu Aug 31, 2023 8:47 am
I'm working on a model in which I need to make multiple ellipsoidal volumes in one layer with separated shell surfaces in other layer. The volumes' shape is based on points which are forced to be part of the volume surface. When I've made these separate shell surfaces manually, mesh generated on the volumes and mesh generated on the shell surfaces are significantly different (and forcing points to both types of surface doesn't help, because they are forced only to the last chosen surface). Also, I've tried to create boundary mesh for the volumes and use it as the shell surfaces, but the 'Create boundary mesh' option creates boundary mesh for all volumes in the model (it's quite tough to distinguish part of this mesh I need) and I cannot see how to create it only for volumes in chosen layer. It is possible to create boundary mesh only for one layer? Or is there another way to create mesh on the shell surfaces compatible with mesh on the volumes?
Thank you!
Thank you!
