Structured mesh is not working
Daniel
Post by Daniel »
I've got the academic license 16.1.2d and with simple square example from user manual the option
Mesh->Structured->Surfaces->Assign number of division to surface lines
is not working. After the selection, the lines do not became red indicating the selection, so I can't mesh the square.
Also, the delete option is not working for surface. When I try to delete the square just created (Delete->Surfaces) again the lines do not became red (none selection is made).
Thanks for any help.
Re: Structured mesh is not working
This seems a typical problem with your graphic card/driver and OpenGL
see this F.A.Q to try to avoid it
https://gidsimulation.atlassian.net/wik ... MS+Windows
Daniel
Post by Daniel »
Thanks !!!
Daniel
Post by Daniel »
Unfortunately it did not worked.
I have set:
Preferences->Graphical->System->Safe Visualization Mode
and it did not worked. It seems to be unable to delete 'Surfaces' and 'All types' at once.
The surface is not shown after created (like previous versions), but the model is analysed normally.
Maybe your 'GiD user settings file' has something wrong, reset them:
https://gidsimulation.atlassian.net/wik ... references
