Mutiple .post.res files
Posted: Thu Oct 20, 2022 8:21 pm
Hello there!
I'm working with a pre-existent F.E. code and we use GiD for pre- and post-processing (GiD 14.*).
The last collegue working on this code has written it so that multiple .post.res files are generated during analysis (all files have the same information, changing only the results for the respective time step). One file named '<model's_name>.post.res' is generated with the final results and during the analysis several files with an ordering name (e.g. 00001.post.res, 00002.post.res, and so on) are generated.
I can easily open the post-processing results from '<model's_name>.post.res', even automatically by switching to postprecess environment, but not from the others. I have tried different approached, but I just can't find a way.
I would like to know how can I open those multiple .post.res files, in order to see the multiple time steps recorded. Can you help me?
